Hi guys.
I currently have:
Athlon XP 2400+
Gigabyte GA-7DXR
512mb RAM (PC2100 - DDR266)
ATi Radeon 9800 Pro (AGP)
Motherboard is at it's limit and is also has a few dodgy capacitors.. its time to upgrade.
I'm pretty set on going with a dual-core setup.
I don't want to spend ££££ in order to have the latest. I'm not that bothered.
Few questions for you:
1) Do I go Intel Core 2 Duo or AMD X2?
Cheapest C2D is £110.44 (the E6300) and the cheapest X2 is £92.81 (the 3800+). Apart from this, what to look for? What are the advantages of each?
2) What are the important features to have on a mobo these days? I'm not interested in having SLI video cards... what else?
3) I have a 20-pin power supply. Can I re-use this? I've heard mixed opinions. Some say you can use it with a 24-pin motherboard, others say no. Opinions?
Cheers
Chris
I currently have:
Athlon XP 2400+
Gigabyte GA-7DXR
Cheers
Chris
