Upgrade suggestions
21 Dec 2018
Hello folks
I purchased the "Titan Spinosaur" from OC back in December 2011.
Over the years ive upgraded the GPU/Fans/RAM (all fairly beginner level)
I think the next required upgrade is the Processor, however I am totally lost when it comes to which one to get.
Currently its running the: Intel Core i5 2500K 3.30GHz
Overall System specs below:
ASUS P8Z68-V Motherboard
16GB DDR3(8 of which is HyperX FURY 8 GB (2 x 4 GB) DDR3 1866 MHz)Not sure what the other 8 is at it came with.
Sapphire RX 580 Nitro+ 4 GB GDDR5
My wife just just bought me a GMX silent case as a Christmas present as I'd love a quiet machine, so will be moving everything over to there and building upwards.
Any general advice on what to buy & upgrade order would be greatly appreciated.
You're correct I unintentionally have. I'd say I've budgeted about 400/500 for any changes now. That being said, if the upgrades can be purchased across 2019, £1000? However best value for money options would be appreciated. Thank you :)
what are the other specs of the system? do you have an ssd?
also if you're upgrading the backbone of the system (cpu/mobo/ram) you'll have to reactivate windows...if it's oem windows and you don't have the key it can get potentially problematic if you don't know what you're doing
Honestly i'm that inexperienced with this I dont know what other specs would be relevant.
My basket at Overclockers UK:
Total: £365.43 (includes shipping: £10.50)
you havent told us what power supply you have, so i'm assuming it's at least half decent.
