Upgrade System and keep XP Product Key, need help!?
10 May 2004
South UK
Hey guys and gals,
Im going to be upgrading my system very soon but want to change pretty much all the hardware. I have read that you can only activate your Windows XP online a certain number of times before it reaches its limit. After which you have to enter a new product key, ie, buy another Windows XP! What a rip off, all I want to do is upgrade my computer and re-install my genuine copy of windows! Naughty micro$oft!
Is there any way of backing up your product key to use on the upgraded system, the only catch is I'm changing the Harddrive too, so how would re-install the original key?
Many Thanks, M.
If you are installing a new motherboard then I'm sorry you'll just have to buy a new windows xp licence :)
Does the activation only recognise changes to the motherboard then? I thought if you changed other bits, it would see that too?
M.
