- 11 Aug 2003
- Taunton, Somerset
Hi all
I think its time to make some changes to the IT setup in my house. I currently have an old toshiba laptop that isn't much good for anything anymore (only used for playing films on my TV). I also have 2 PCs
The first PC:
Case: HAF32
CPU: i7 920 (skt 1366)
Cooler: Corsair H50
Mobo: GA-EX58-UD5
Ram: Patriot Viper 6GB DDR3-1600
HDD: 3 X Samsung HD103SJ Spinpoint F3 1TB
DVDR: Sony AD-7240S 24x DVD±RW
GFX: 2 X Nvdia GTX260
PSU Corsair 850HX (CMPSU-850HXUK)
I have had a lot of issues with this PC. I have flashed the BIOS to f12 but looses this and returns to f7 as a rusult it looses my overclock settings. I gave up trying to use the f12 BIOS for the overclock and stuck with the f7 BIOS. I also have had issues with th RAID-5 setup in that it kept marking one disk as faulty and so I have bought new disks on 2 seperate occations to rebuild the array - after the second time I tested the "faulty" disk to find that it was OK
second PC:
Case: Coolermaster N300
CPU: AMD PHENOM II X4 Quad Core 955
Cooler: Sunbeam 120 mm Core-Contact Freezer
Mobo: K9A2 Platinum
Ram: 4GB Kingston HyperX
HDD: 2 X 250GB
GFX: 2 X MSI GTX460
PSU Be Quiet 900W
I also have a Prolimatech Megahalems Rev B cooler
My thoughts are to bin the laptop, get a NAS, use the raspberry pi as a media streaming device to the TV and build a new PC.
If I was going to build a haswell based PC then what would you guys recommend and is there anything worth keeping from the two builds above.
As an intial build how about:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x MSI HD 7970 GHz Twin FrozR OC BE 3072MB GDDR5 PCI-Express Graphics Card with FREE GAMES £259.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler £59.99
1 x Kingston HyperX Genesis Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3K2/8GX) £53.99
1 x Coollaboratory Liquid Pro Liquid Metal Thermal Paste £8.99
Total : £867.92 (includes shipping : £10.00).
This is a bit more than I wanted to spend idealy no more than £800
It will be used for some gaming, occasional virtual machine testing and I am a member of the folding team - see sig
Any advice gratefully received
The first PC:
Case: HAF32
Cooler: Corsair H50
Mobo: GA-EX58-UD5
second PC:
Mobo: K9A2 Platinum
HDD: 2 X 250GB
GFX: 2 X MSI GTX460
PSU Be Quiet 900W
YOUR BASKET
