Upgrade time - again !
10 Jun 2003
Looking at my 3 yearly upgrade program and came across the Koolance PC3-736BK Lian Li V2000 :D
Has anybody any experience with these ? Do they use quality components and are they worth the money ? :confused:
Not used on personally but WJA96 has another model and rates it.
Having seen (but not used) one they do seem to be done very well, and the cooling just by looking at reviews is very good for a all in one solution; would go as far as saying probably the best range of all in ones about at the moment.
Well worth the money if you have enough and do not want to go custom.
Cheers Yewen ;)
I didn't want to start hacking holes in a shiny new V2000 so was looking for an all in one solution and this seems to fit the bill.
As for cost its no more than a top end graphics card and will last a hell of a lot longer :D At least thats what I keep telling myself to justify it !
