Hello gentlemen of general hardware,
I make my way to you, from GD, to ask for your advice. I am currently running a slightly budget & bung together rig, the specifications are as follows.
AMD A5800K 3.8GHZ APU
8GB Ram
MSI 7850 Twin Frozr 2gb
Gigabyte GA-F2A75M-D3H Motherboard
XFX Pro450W PSU
1 x 500gb HDD, 1 x 1TB HDD, 1 x 128GB Samsung SSD
CoolerMaster CM690 II Advanced Case
Now, I am looking at investing money into my system over the next month or so, rather than blowing it all up the wall on drinking, change of life style and all that! The way I see it, I can have circa £500 in a months time to upgrade the system.
I am giving genuine consideration to moving over to Intel, and teaming up a 4670K, Corsair H100i for cooling, MSI Z87 GD65 & a new PSU to be Haswell compatible too.
The month after, I shall upgrade the graphics card, most likely to a MSI Radeon R9 280X so the card & motherboard should match, to provide a nice looking red & black theme. This leaves me with the problem that my case is currently of a blue theme, well the lighting anyway. Would you reckon I should just change the fans in the case for something red? Or look into moving up to the Storm Trooper which I believe comes with a red light theme already? I am also looking to get a bit less noise from my system too, as it is currently quite audible, so is the Trooper better for noise than the CM690?
Thanks for any hints, tips and advice. Not only helping me with an upgrade, but also getting myself back on track.
Thanks again,
Yours, Lovingly,
Spangles
x
8GB Ram
XFX Pro450W PSU
Thanks again,
Yours, Lovingly,
Spangles
x
