Hi,
I have tried to locate the correct RAM modules to upgrade my system from 8 to 16gb.
My existing RAM is this,
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9
1600MHz Dual Channel Kit (KHX1600C9D3X2K28GX)
According to Speccy, it's running @ these specs,
8.00GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
Has the HyperX line been discontinued? Are these timings normal?
All the stuff I have looked at does not have theses specs.
My mobo - Asus P8Z68-V PRO GEN3 Intel Z68 (Socket 1155) DDR3
CPU - Intel Core i5-2550K 3.40GHz (Sandybridge) Socket LGA1155
Any help would be appreciated.
