Upgrade to 3d?
5 Sep 2011
so I'll be buying another 7950 3gb asus TOP card soon to crossfire the two of them, My question is about 3d for AMD cards. The reason I'm cross-firing two is so I can get more fps for a 3d setup and I'm a bit skeptical as to monitors.
I know that if AMD is put through HDMI they will only show 720p
I'm looking for a 27" monitor that will run amd 3d at around 120hz @ 1080p, so I'm assuming it needs a display port connector to take full advantage? I'll also be buying tri-def so I can run most of the games I use in 3d.
Any help would be great :)
