My friend is selling me his 4770k so i'm looking to do an upgrade using this.
My current PC is
i7 950
8GB 1600Mhz RAM
Nvidia 460GTX
So obviously I need a new motherboard and graphics card. I have also heard that to get the best out of the 4770K's you need fast RAM. Is this true?
So ideally I want to spend about £500 max and I was thinking of the below components.
Gigabyte Z87X-UD4H Intel Z87 Motherboard with FREE COOLERMASTER SEIDON 120V COOLER
Asus GeForce GTX 770 DirectCU OC 2048MB Graphics Card
TeamGroup Xtreem LV 16GB (2x8GB) DDR3 2666MHz Dual Channel Kit
I do have a few questions which hopefully you guys can help me with?
Will I see a performance increase if I get some 2400Mhz RAM? Or should I just re-use my 1600Mhz RAM?
I've had bad experiences with AMD cards in the past but is it worth now going back for a 290X and spending a bit extra? The one below is £40 more but should be much better performance than the Nvidia 770 right?
http://www.overclockers.co.uk/showproduct.php?prodid=GX-017-VX&groupid=701&catid=56&subcat=1752
With the free Seidon cooler, am I right in thinking this is a self contained water loop? I won't have to water cool the rest of my system will I? Is this a good cooler?
Thanks guys
My current PC is
i7 950
8GB 1600Mhz RAM
Nvidia 460GTX
Thanks guys
