Upgrade to Current Loop
5 Dec 2009
Near OCUK
Hi All,
Looking to improve on the current setup I have at the moment and add in the graphics cards to the loop.
What I have at the moment, is a simple CPU loop.
PUMP > CPU > 360 RAD > Tube RES
I'm looking to add 2 7970s into the loop and have a couple of questions, that hopefully someone will be able to answer.
Will the 360 RAD be enough, once the 2 7970s are added?
Will adding another reservoir, maybe into a bay help with cooling?
What components, do I need to add the 7970s into the loop? Any recommendations?
Would I be better off adding a second loop?
I appreciate there are a few questions, any help would be great!
Thanks guys!
- How thick is the 360 rad? if not an 80mm monsta then I'd say no.
- adding another res will not help with cooling (if you add LOADS it would increase the time it takes to reach your maximum temperature though)
- full cover waterblocks with a multi-gpu fitting or bridge
OR
Core only blocks with a multi-gpu fitting or bridge + heatsinks for vram and mosfets
-No
Thanks - Will take a look at whats available. Definitely want to go for the full cover blocks. Any real differences between Nickel/Acetal/Plexi - Or purely cosmetic?
Was looking at the EK-FC7970 CSQ.
Will look to add another 360/240 rad.
Thanks again.
