- 7 Oct 2009
In a couple of months I plan to upgrade my current PC to a i7 920 chip.
Current PC:
Case: Coolermaster 690
CPU: Intel Q6600
M/B: Asus P5k-e
Ram: 4GB 800Mhz DDR2
Graphics: ATI HD4850
Sound: Soundblaster x-Fi
2 x Sata HDD (500GB, 250GB)
Power Supply: Jeantech 600W Artic
I intend to buy the CPU, Motherboard, memory and cooler, and replace them in the same case.
I have a couple of questions:
1. To save on cost, is a cheaper motherboard such as the Asus P6T SE, good enough?
2. For the memory would CL9 be that much worse than say CL8?
I aim to overclock the i7 920, but have never done this before, is it easy for a newbie to do. Or would I be better spending the extra on an overclocked bundle from Overclockers?
Buying the cheaper components would save about £70 over the cheapest bundle deal I’ve seen. Is the bundle worth the extra cost?
I want to upgrade as I have a lot of AVCHD camcorder footage I want to edit. I find the Q6600 struggles a bit. I’m not a heavy gamer, so SLI etc doesn’t interest me.
Current PC:
CPU: Intel Q6600
M/B: Asus P5k-e
