I would like to know how you magically over few days first increase the budget from 500 to 900, then to 1100 and now to over 1400.
But yeh anyways, after all it's your choice.
I just don't think it's worth it, would still go with the phenom just with the small exception that ill wait a week or two now and get the new 965BE : ).
Either way you choose, the 295 is overkill.
Just get 1 275 or 4890 and then if this isnt enough for you ( and I bet it will be more than enough ) get another one for SLI/CF.
PS.
That review doesn't really say much, all I see there is phenom winning in some games and i7 in the other ones ? Where the most difference on either side is about 2-10%.
PS.
Across all of the games and all of the resolutions we tested, the Phenom II system delivered frame rates just as playable as the Core i7 system.
