Upgrade to iCore
23 Dec 2008
Hi folks,
Now that I have a new graphics card, SATA-3 hard drive, 6600T case and the H60 cooler.
I want to upgrade to iCore, and keep my Q6600 in my bank's safe box.
I need advise on the motherboard seriously. What do you folks think about Asus P8Z68-V-PRO?
And by the way, are USB 3.0 bandwidth fully utilitzed?
THANKS IN ADVANCE!
Best regards
Peter
Hi folks,
Good board, but I'd get a gen 3 motherboard (PCIE 3.0 + Ivybridge support). Else it's good, but personally, I'd still get a Gigabyte Z68XP-UD4 :)
Not really sure. There are some SATA3 USB memory sticks around, and possibly external hard drive enclosures. The only devices I can think off that would really benefit from it.
Unless things have changed between the P67 and Z68 chipsets then, afaik, you won't get the full speed possible from USB 3.0.
The X58 chipsets are the only way to get the full speed, unless there are some half way decent USB 3.0 PCI cards about.
What good would Z68XP-UD4 do, please enlighten me? Thanks!
Excuse me, do you mean that X58 is superior than Z68 and P67, sorry I am not really into the chipset side of things, so please tell me more, thank!!
What is your source of information that USB 3.0 works better on X58 than P67 or Z68?
None of those chipsets natively support USB 3.0 so they all use a discrete add on controller.
I'll find it for you in a sec Surveyor, its been known for a while though.
Its the reason why the black magic intensity shuttle (HD capture card) doesn't work on the new chipsets properly.
As i said above I'm not sure if its the case with the Z68 boards though.
I don't think it has much over the P8Z68-V Pro tbh. Similar sort of boards, but I like the layout and looks. Secondly, the P8Z68-V pro doesn't introduce anything particular over the standard P8Z68-V. A few more SATA3 ports, USB3 ports, and a on-board power switch. You might as well go for the regular P8Z68-V, which has same VRM design, same Bluetooth support, ect...
Z68 should have :
- IvyBridge support.
- Gen3 boards support PCIE 3.0.
- Intel SRT (not very useful).
- Lucid Virtu (not very useful).
- QuickSync (useful in some cases of video transcoding).
To be honest, Gigabyte dropped a clanger on the new SandyBridge chipsets. Their P67 are good but expensive, their lack of UEFI, their spotty Z68 feature support, and now their contested claims about their boards supporting IvyBridge and PCIE3 natively. Someone there is gonna get the sack for sure. Their build quality is still solid though.
@Surveyor.
Can't find the original posts for you. I had a huge convo with the guys @ black magic about their intensity shuttle. USB 3.0 speeds can't be tested with HDD's because the don't reach the speeds possible to show the bottleneck.
Whats the problem is is that, like you said the USB 3.0 controller isn't native so uses a controller which in turn uses the PCIe lanes.
On mainstream boards, 1155 and 1156 the PCI bandwidth is centred around the x16 graphics lanes. (the whole only run cards at 8x, 8x issue)
This limits the PCIe 1.1 lanes to 250MB/s. which the USB 3.0 controllers use.
this isn't the case on the X58 boards.
Ah, saying that have a read of this, might explain it better than I can: link
