upgrade to Shuttle
17 Jan 2005
London
Hi guys, just looking for a bit of advice really.
I'm looking at replacing my current pc with a much more compact, carryable and more powerful rig. I've been looking at a Core 2 Duo E6600, 2GB of DDR2 ram and transplanting my 7800GT, DVD drive and other stuff, probably not going to overclock it as i've never had the urge to overclock my current rig. The primary uses will be Photoshop (manipulating 5D RAW files), gaming BF2 + 2142 and the like, playing media, plus the usual IM, web surfing etc.
Now to the question, what barebones shuttle would be best? i'm looking at the SD37P2 and SD32G5.
What would be the benefits of choosing either?
Will the 250W psu on the 32 be enough for 2 HDDs and an upgrade to the gfx at a later date?
the different chipsets, will it make much of a difference either way?
what ram would you go for ~£160?
i've not kept abreast of things since i built my last pc so not really sure what the deal is with Shuttle or the newer intel stuff and i need some pointers :)
Another consideration is if you plan to fit a Creative sound card in the future should you not be satisfied with the on-board audio.
Creative don't have a PCI Express option, and I don't see them releasing one any time soon. So you'd be limited if you went with the SD37P2.
I remember reading in the past that Creative external options didn't handle positional audio for games like Battlefield 2. Don't know if that's still the case.
Thanks for the info :) i've not really thought about external sound cards, but talking about sound the coaxial s/pdif on the SD37P2 would be handy to connect to my hi-fi which is the method i use now :)
