Definitely, the non pro version is a lot slower but as your motherboard holds you back it won't be an issue as you'll never reach the expected speeds on SATA2 ports.
So 120gb or 250gb samsung is a good choice![]()
read speeds are the most important,the faster it reads your data the quicker things load/run ect
Seems your motherboard has no Sata 3 ports to extract full performance from a Sata 3 SSD.
I thought my board has Integrated high speed SATA 3Gb/s? Is this not SATA 3?
http://uk.gigabyte.com/products/product-page.aspx?pid=2846#sp
