Please bear with me, I am out of touch with the latest partition software and the latest SSD drives.
I currently have a Macbook Pro (15" early 2011). It is the intel core i7 2.2 ghz with 8gb RAM (2 x 4gb 1600 mhz modules).
It has the older Toshiba 750gb (5400 rpm) drive that I always found slow. In early 2011 when my brain was a little faster, I partitioned the drive and installed Windows Pro 7 (x 64) into a 250 gb NTFS partition to run several windows programs including Quicken 2000. Leaving 500gb for Mac OS X. Naturally it has Boot Camp version 4 installed allowing me to boot to OS X 10.11.4 (El Capitan) or Windows 7. It is necessary for me to keep this configuration, because when I go on holiday (frequently), I use Quicken 2000 for my finances.
I have been looking at upgrading the HD to an SSD (BX200 960GB SSD SATA 6Gbps Solid State Drive (CT960BX200SSD1)) or similar.
My question is as follows;
Is it possible to just clone the current HD (contents and partitions) to an SSD and carry on using both the Mac OSX and Windows 7 as I am doing now?
I was looking at making the Mac OS partition smaller (say 230 gb) when cloning so that I could save some pennies going to a smaller size SSD say 500gb, although this is not imperative and if it best left alone at the full 500gb then I will.
I would like advice from any knowledgeable reader on how to proceed with pointers to partition/clone software. Keeping it simple is the name of the game. If this was a standard PC, I would have no problem.
Two further questions.
1. If I disconnect the DVD writer and couple up an SSD on the end of its cable, would it [SSD] be recognised and would I be able to clone directly from the 750 gb Toshiba to the SSD, and then switch cables back to the normal configuration?
2. Is this software useful for my cloning and changing the size of my partitions?
http://download.cnet.com/Stellar-Partition-Manager/3000-2094_4-75375362.html
Thanks.
Thanks.
