Hey all,
Finally deciding to pull the trigger on an upgrade that's well overdue, its like running through treacle. I am mostly decided on what I should get but I need a bit of a hand from the pro's choosing the right modules to give the best results, also going water which is something I haven't tried before... about time I did!
So without further adoo here is my list with a little bit of justification so you know where I'm coming from.
Edit:- Updated due to feedback
Proposed setup:
Intel Core i7 2600K
Asus P8Z68-V PRO <-- Dont need multiple LAN ports
G.Skill RipJawsX 8GB (2x4GB) F3-12800CL8D-8GBXM <-- Scaled back from CL7
XFX ATI Radeon 6970
Intel 510 250GB <-- Changed from OCZ due to possible BSOD issues with Vertex3
Got a soundcard, X-Fi jobbie.
Modular Corsair HX 620W <-- Reusing.
Cooling:
Swiftech Apogee XT <-- Changed from EK Nickel due to possible flaking issues.
ThermoChill TA120.3
EK-DDC X-RES 100
12V Laing DDC-1T 10W <-- Or go for the 18W? I think the block is low enough restriction.
Koolance VID-AR697
8x (1/2") 13mm ID Barbed Fittings <-- Longer?
3x Scythe Gentle Typhoon 120mm - 1150 RPM <-- For the radiator.
Proposed setup:
Intel Core i7 2600K
XFX ATI Radeon 6970
Cooling:
ThermoChill TA120.3
EK-DDC X-RES 100
Koolance VID-AR697
and I do intend on overclocking it, maybe some softvolt work too but falling short of hardmods. I would prefer ATI because I am able to run my OpenCL programs a damn sight faster that's the main drive on that choice, hoping they have fixed multi-monitor issues...
