9 Apr 2021 at 18:41 #1 TristanHR TristanHR Associate Joined 9 Apr 2021 Posts 4 Currently have a basic build from 2 years ago, looking to play mainly Warzone at 144fps. Any help would be very appreciated. Thanks
9 Apr 2021 at 18:41 #2 TristanHR TristanHR Associate OP Joined 9 Apr 2021 Posts 4 (1x) AMD Ryzen 3 Quad Core 1200 3.40GHz (Socket AM4) Processor - Retail (1x) Gigabyte GA-AB350-Gaming 3 AMD B350 (Socket AM4) DDR4 ATX Motherboard (1x) BitFenix Alchemy 2.0 Magnetic Connect 15 LED-Strip 30cm - Purple (1x) Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139) (1x) Standard Build Systems - Dispatched within 7 working days (1x) Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD416G24 (1x) Kolink Luminosity RGB Midi Tower Gaming Case - Black (1x) Kolink KL-500 500W '80 Plus Bronze' Power Supply (1x) Kingston A400 240GB SATA 6Gb/s 2.5" Solid State Hard Drive - (SA400S37/240G) (1x) Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock* (1x) Cougar Deathfire EX Gaming Mouse and Keyboard - UK Layout (1x) Palit GeForce GTX 1050 StormX 2048MB PCI-Express GDDR5 Graphics Card
9 Apr 2021 at 19:05 #3 mickyflinn mickyflinn Man of Honour Joined 23 Mar 2011 Posts 18,093 Location West Side You would need a new gpu which are difficult to get and highly priced and a new cpu like the ryzen 3600 which has 6 cores. You would also be best to change that psu as the Koolink are budget basic .
9 Apr 2021 at 19:30 #4 TristanHR TristanHR Associate OP Joined 9 Apr 2021 Posts 4 mickyflinn said: You would need a new gpu which are difficult to get and highly priced and a new cpu like the ryzen 3600 which has 6 cores. You would also be best to change that psu as the Koolink are budget basic . Click to expand... Ok so if I get the following should I be good? AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor be quiet! System Power 9 500W 80 Plus Bronze Power Supply
9 Apr 2021 at 19:44 #5 Joxeon Joxeon Soldato Joined 15 Oct 2019 Posts 12,916 Location Uk I'd recomend the ryzen 5 3600 16gb of 3200+MHz ram and an RTX 3060ti/3070/6700XT/6800 you will also want to get a good quaility 650w psu. Try and find a GPU first then add the rest as finding the other bits in stock isn't an issue.
9 Apr 2021 at 20:05 #6 TristanHR TristanHR Associate OP Joined 9 Apr 2021 Posts 4 Thank you. For budget can I look to get: GTX1660 and a 500w PSU? Last edited: 9 Apr 2021
