Hi,
As you are probably aware EK recently added to the Predator range and we have been working with them on bundles and getting the most popular blocks created as QDC.
The QDC allows you to change your GPU water block with great ease if you ever decide to upgrade in the future without draining the loop. Also if your graphics card ever becomes faulty you can just remove it from the loop nice and simple.
Below are the available bundles which you can select any of the blocks to as well. Prices may change when removed from offers.
EK Water Blocks Predator 140 + EK QDC Graphics Card Block Bundle https://www.overclockers.co.uk/ek-w...qdc-graphics-card-block-bundle-bu-008-ek.html
Creating the perfect cooling with minimal effort. Build your loop with this bundle to improve cooling and without the need for a full watercooling loop.
ORDER NOW
EK Water Blocks Predator 240 + EK QDC Graphics Card Block Bundle https://www.overclockers.co.uk/ek-w...qdc-graphics-card-block-bundle-bu-009-ek.html
ORDER NOW
EK Water Blocks Predator 280 + EK QDC Graphics Card Block Bundle https://www.overclockers.co.uk/ek-w...qdc-graphics-card-block-bundle-bu-007-ek.html
ORDER NOW
EK Water Blocks Predator 360 + EK QDC Graphics Card Block Bundle https://www.overclockers.co.uk/ek-w...qdc-graphics-card-block-bundle-bu-00a-ek.html
ORDER NOW
The blocks are also available to buy separately:
EK Water Block EK-FC1080 GTX - Acetal+Nickel (QDC) @ £119.99 inc VAT https://www.overclockers.co.uk/ek-water-block-ek-fc1080-gtx-acetal-nickel-qdc-wc-9al-ek.html
EK-FC1080 GTX is a high performance full-cover water block for nVidia Founders Edition design GeForce GTX 1080 series graphics cards.
Only £119.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC1080 GTX FTW - Acetal+Nickel (QDC) @ £129.95 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-ftw-acetal-nickel-qdc-wc-9cs-ek.html
EK-FC1080 GTX FTW is a high-performance full-cover water block for EVGA® GeForce GTX 1080 FTW series graphics cards.
Only £129.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FC1080 & 1070 GTX Strix - Acetal & Nickel - Predator Pre Filled @ £129.95 inc VAT https://www.overclockers.co.uk/ek-w...and-nickel-predator-pre-filled-wc-9bg-ek.html
Designed for use with the EK Water Blocks Predator AIO Liquid Cooler. This pre filled water block is easy to install using the incuded quick disconnect
ORDER NOW
EK Water Blocks EK-FC1080 GTX TF6 - Acetal+Nickel (QDC) @ £129.95 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-tf6-acetal-nickel-qdc-wc-9ct-ek.html
The EK-FC1080 GTX TF6 is a high-performance full-cover water block for MSI non-reference design MSI® GeForce® GTX 1080, -1070 and 1060 GAMING series graphics cards.
ORDER NOW
EK Water Blocks EK-FC1080 GTX G1 - Acetal+Nickel (QDC) @ £122.99 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-g1-acetal-nickel-qdc-wc-9cu-ek.html
EK-FC1080 GTX G1 is a high-performance full-cover water block for GIGABYTE non-reference design NVIDIA® GeForce GTX 1080, -1070 and 1060 series graphics cards.
Only £122.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC Titan X Pascal - Acetal+Nickel (QDC) @ £128.99 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc-titan-x-pascal-acetal-nickel-qdc-wc-9cv-ek.html
EK-FC Titan X Pascal is a high-performance full-cover water block for NVIDIA Titan X graphics card, based on Pascal architecture (GP102)
Only £128.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
