**UPGRADE YOUR NETWORK WITH POWERLINE**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
As you are aware power line has been around for a short time and is an easy way to upgraded your network without adding network cables through your house.
Power line adapters are a great way to move your network to any room in the house enabling you to get the best network speeds for your PC and consoles that are not close to your router.
I am currently using power line at home to avoid using wireless on my console as I would not like to risk the poor connection mid gaming session as no one likes lag and drop outs.
So below are a select few products that I recommend from our vast range to help anyone who wants to improve the networking in your home.
TP-Link AV500 Nano Powerline Adapter Starter Kit (TL-PA411KIT) @ £25.99 inc VAT
What This Product Does
TP-LINK 500Mbps Nano Powerline Adapter Starter KIT TL-PA411KIT turn your existing powerline into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapters into your power sockets and you can establish networking infrastructure in a flash. With a speed of up to 500Mbps, TL-PA411KIT transmits multiple HD streams and even 3D movies to every room, making it a great choice for an easy to build multimedia entertainment network.
Features:-
- HomePlug AV standard compliant, high-speed data transfer rates of up to 500Mbps
- No new wires, Easy Plug and Play operation, No configuration required
- Super small design with a new exterior, blends indiscreetly in front of any power outlet
- Patented Power-Saving Mode automatically reduces power consumption by up to 85%*
Specification:-
- Interface: 10/100Mbps Ethernet Port
- Plug Type: UK
- Power Consumption: < 2.1 W
- Range: 300M in house
- System Requirements: Windows 2000/XP/2003/Vista, Windows 7, Mac, Linux
- Dimensions: 3.6(W) x 2.2(D) x 1.2(H) inches
Only £25.99 inc VAT.
ORDER NOW
TP-Link AV500 2-port Powerline Starter Kit (TL-PA4020 KIT) @ £29.99 inc VAT
Highlights:
No new wires, easy Plug and Play operation, no configuration required
Twin Pack design helps establish a basic powerline network
Actual data will vary due to the network conditions and environmental factors.
TP-LINK's AV500 2-port Powerline Starter Kit, TL-PA4020 KIT, turns your existing powerline into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapters into your power sockets and you can establish networking infrastructure in a flash. With a speed of up to 500Mbps, TL-PA4020 KIT transmits HD streaming and even 3D movies to every room, making it a great choice for an easy to build multimedia entertainment network.
Up to 500Mbps for up to 300 Meters
With advanced HomePlug AV technology, TL-PA4020 KIT provides users with stable, high-speed data transfer rates of up to 500Mbps on a line length of up to 300 meters. Together with its built-in AES encryption, the TL-PA4020 KIT is a great choice for a whole home solution to connect all network compatible devices, from computers and game consoles to set-top boxes for IPTV, printers and NAS hard drives.
HD Streaming
Up to 500Mbps powerline speed ensures smooth HD streaming.
Reduce Power Consumption by up to 85%
The TL-PA4020 KIT, a new-generation Powerline Adapters, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 85%*.
*Actual data will vary because of the network conditions and environmental factors.
Plug and Play
You can set up a hassle-free powerline network within minutes with TP-LINK powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
*Note: Powerline adapters must be deployed in sets of two or more.
Support QoS for Advanced Multiple-media Optimization
The Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Game, Audio or Video, Voice over IP, and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
Only £29.99 inc VAT.
ORDER NOW
Dynamode 500mbps AV Powerline Homeplug - Twin Pack (HPLG500T) @ £23.99 inc VAT
Welcome to the next generation of HD-Ready PowerLine Homeplugs for your digital lifestyle. The HPLG500 enables a fast connection of up to 500Mbps allowing a super-fast connection to carry the latest generation digital content including Video Streaming, high-quality Audio, lag-free gaming and of course your normal Internet traffic, all of which will now run faster, with less delay.
Setup is as easy as plugging in a power socket. Simply connect one of the HPLG500T adapters into any electrical Power Socket and connect your Computer, Game Console or Media Centre for example. Now, plug in the other HPLG500T into another electrical Power Socket, maybe close to your existing Broadband Router or Network Switch. Ideal for creating both permanent or temporary networks around the Home or Office and by using your electrical wall sockets, this means you can run long distances be assured of absolute Network security in an instant.
Features:
- Next generation PowerLine enabling up to 500Mbps connection speeds
- Supports HD-Ready Video and Audio content over your electrical power sockets
- Ideal for creating instant, high-speed Networks at home or the office
- Compatible with other 500Mbps vendor PowerLine devices
- Built-in 10/100Mbps Switch Port on HPLG500T
- Secure, easy-to-use AES Encryption to keep you safe online
- Supports IP-TV (Internet of TV) and VoIP applications instantly
- Boost your online Gaming experience with better, more fluid gameplay
- No setup or software required. Just plug in and go
- Stylish, low power design with advanced power saving features
- Compatible with Xbox360TM, PlayStation2TM and most other consoles
- Compatible with WindowsTM, Mac OS XTM, LinuxTM and other Operating Systems
Only £23.99 inc VAT.
ORDER NOW
TP-Link AV1000 2-Port Gigabit Passthrough Powerline Starter Kit (TL-PA7020PKIT) @ £59.99 inc VAT
Bring Your Home Network Into The New Age
1000Mbps: Ideal for Slick streaming and Smooth Downloads
Comes with advanced HomePlug AV2 technology, TL-PA7020P KIT provides users with high-speed data transfer rates of up to 1000Mbps, which is ideal for bandwidth intensive applications such as multiple HD/3D/4K video streaming, online gaming and large file transfers.
2 Gigabit Ports for Maximum Connectivity
With 2 gigabit Ethernet ports, TL-PA7020P KIT can simultaneously connect up to 2 wired-only devices. This makes the TL-PA7020P KIT the perfect home entertainment companion. Connect any 2 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go!
Plug and Play, No Configuration Required
Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you’re done!
Extra Power Socket for Additional Devices
Where sockets are at a premium, the TL-PA7020P KIT with an integrated AC pass-through power socket, means the powerlines can be used like a traditional electrical socket. Plug your smart TV or games consoles into the powerlines, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting powerline performance.
Reduce Power Consumption by Up to 85%
TTL-PA7020P KIT, a new-generation of powerline adapter, with its practical design and sophisticated Power-Saving Mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%.
Key Features:-
- HomePlug AV2 standard compliant, high-speed data transfer rates of up to 1000Mbps, supports all your online needs.
- 2 gigabit ports create secure wired networks for desktops or IPTVs.
- Integrated power socket ensures no power outlet goes to waste.
- Plug and play, no configuration required.
- Patented Power-Saving Mode automatically reduces power consumption by up to 85%.
Specifications:-
- LAN Type: 10/100/1000
- Data Transfer Rate (upto): 1000 Mbps
- Standards and Protocols: N/A
- Security: AES
- Connectors: 2 x RJ45 - 10/100/1000 1 x UK Power Plug
- Power Consumption (Max): 6 W
- Dimensions: 131 x 42 x 72 mm (WxHxD)
Only £59.99 inc VAT.
ORDER NOW
TP-Link AV1200 Gigabit Passthrough Powerline Starter Kit (TL-PA8030P KIT) @ £79.99 inc VAT
Using your home’s existing electrical circuit, TP-LINK’s TL-PA8030P KIT AV1200 3-Port Gigabit Passthrough Powerline Starter Kit turns any electrical socket into an Internet connection. Simply plug into your wall socket and you are ready to enjoy HD streaming and gaming, no configuration required. You also won't lose a socket with its integrated pass through socket included! With speeds of up to 1200Mbps for smooth Ultra HD streaming, online gaming or faster downloads, TL-PA8030P KIT is a perfect home entertainment companion.
1200Mbps! Perfect for Bandwidth Demanding Activities
With its advanced HomePlug AV2 technology, TL-PA8030P KIT is introducing a powerline generation for even faster data transmission in the home network. TL-PA8030P KIT supports 2x2 MIMO* with beamforming, so users benefit from ultra-fast data transfer speeds of up to 1200Mbps. Perfect for bandwidth demanding activities like streaming Ultra HD video to multiple devices simultaneously, online gaming and large file transfers. *The Multiple Input Multiple Output functionality within HomePlug AV2 significantly improves data transfer rates especially during peak periods. It uses any two electrical wire lines within a 3 wire network to boost performance.
3 Gigabit Ports for Maximum Connectivity
With 3 gigabit Ethernet ports, TL-PA8030P KIT can simultaneously connect up to 3 wired-only devices. This makes the TL-PA8030P KIT the perfect home entertainment companion. Connect any 3 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go!
Where sockets are at a premium, the TL-PA8030P KIT with an integrated AC pass-through power socket, means the powerlines can be used like a traditional electrical socket. Plug your smart TV or games consoles into the powerlines, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting powerline performance.
TL-PA8030P KIT is easy to use as follow: 1. Plug a powerline adapter into a wall socket and connect it to the router, via an Ethernet cable. 2. Plug another powerline adapter into a wall socket in another room and connect it to your Internet enabled device via Ethernet - and you are done! The powerline adapters will automatically connect to extend your network. The “Pair” buttons on the powerline can also be utilized for securing or managing multiple powerline adapters in your home powerline network.
TL-PA8030P KIT, a new-generation of powerline adapter, with its practical design and sophisticated Power-Saving Mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%*. *Actual data will vary in different network conditions and environments.
Features:
HomePlug AV2 standard compliant, fully interoperable with HomePlug AV, ideal for using multiple HD/ Ultra HD devices simultaneously
High-speed data transfer rates of up to 1200 Mbps, supports all your online needs, with three years warranty
3 Gigabit ports provide secure wired networks for desktops, smart TVs and games consoles
TP-LINK powerlines are compatible with all broadband routers and powerlines, plug and play, no configuration required
Warranty Information:
Manufacturer: tp-link
Warranty Type: Direct with Manufacturer
Manufacturer Website: http://uk.tp-link.com
Warranty Period (yrs): 3
Only £79.99 inc VAT.
ORDER NOW
Asus 300 Mbps Wi-Fi HomePlug AV500 Powerline Adapter Kit (PL-N12 KIT) @ £69.95 inc VAT
Get Wi-Fi from any power socket
The ASUS PL-N12 Kit instantly extends your wired and wireless network to any hard-to-reach areas of your home. It uses high-speed HomePlug® AV powerline technology to make a connection — over existing mains wiring — between your router and a Wi-Fi access point that you can plug into any mains socket. This gives you a convenient, stable 300 Mbp Wi-Fi signal anywhere, without physical clutter!
With two Ethernet LAN ports on the Wi-Fi access point, you can also use PL-N12 Kit to connect to any wired network devices, such as desktop PCs, games consoles or smart TVs. PL-N12 Kit is amazingly easy to set up: just plug the adapters in and press a button to create a secure network connection between them.
Setting up Wi-Fi is just as easy, with a one-click clone feature that does away with the need for entering network names or passwords. It really is that simple! Clever noise filtering technology prevents performance being affected by electrical interference, and Roaming Assist keeps you connected to the best Wi-Fi signal as you move around the house.
300 Mbps Wi-Fi plus great connectivity
Even though it’s compact and convenient, PL-N12 Kit has full networking capabilities. Your mains sockets become 300 Mbps Wi-Fi nodes, while the two Ethernet LAN ports can be used to connect PCs, games consoles, smart TVs or any other wired network device!
Instant plug-and-play setup!
Setting up PL-N12 Kit is incredibly easy! Simply plug it in and you can enjoy the internet via Ethernet cables or Wi-Fi.
Step1:
Connect the smaller adapter to your router with a network cable, then plug it into a power outlet.
Step2:
Plug the larger (Wi-Fi) adapter into any power outlet, then connect your devices via Wi-Fi or the network ports on the adapter — and that’s it.
One-touch Wi-Fi setup
With PL-N12 Kit you don’t have to enter complicated wireless network names or passwords! Just press the Clone button on the Wi-Fi adapter and the WPS button on your router, wait a few moments, and that’s it! Once it’s done you can place the Wi-Fi adapter anywhere to enjoy seamless networking across your entire home or office — there’s no need to configure the adapter again!
One-touch security
To create a really secure powerline connection, just press the Pair buttons on both adapters. This sets up a secure encrypted connection between the adapters, and prevents anyone connecting an unauthorized adapter to your powerline network (you can always add your own adapters, of course!). This is perfect if you live somewhere with shared mains wiring, such as an apartment — your neighbors won’t be able to accidentally connect to your network, so your data will be kept safe and sound.
Features
No network cables needed: Plug-and-play networking via the mains for convenient, clutter-free networking.
Solve two problems at once: Fast, stable 500 Mbps HomePlug® AV connection plus powerful 300 Mbps 802.11n Wi-Fi access point.
Easy setup: Plug-and-play setup, with easy Wi-Fi network cloning.
Rock-solid security: Encrypted pairing blocks unauthorized devices.
Flexible connectivity: Connect multiple devices via powerline, two Ethernet LAN ports or Wi-Fi.
Standby mode: Sleeps automatically when not in use to cut power consumption by 80 %.
Interruption-free Wi-Fi: Roaming Assist automatically keeps you connected to the strongest Wi-Fi signal.
Specification
Port Attributes: 2 x 10/100 Ethernet Port(s)
Connection: 2 x RJ45
Dimensions: 98 x 54 x 40 ~ mm (LxWxH)
Encryption: Powerline Security 128-bit AES
Wireless Security: WEP, WPA/WPA2, WPA-PSK/WPA2-PSK Encryption
Powerline Speeds: Up to 500Mbps
Wi-Fi data rate: 802.11n: Up to 300Mbps(dynamic), 802.11g: Up to 54Mbps(dynamic), 802.11b: Up to 11Mbps(dynamic)
Only £69.95 inc VAT.
ORDER NOW
ZyXEL 1000 Mbps Powerline Gigabit Ethernet Adapter - Twin Pack @ £41.99 inc VAT
The ZyXEL PLA5206 1000 Mbps Powerline Gigabit Ethernet Adapter is based on the latest HomePlug AV2 standard with data transfer rates up to 1000 Mbps*. You can plug into existing electrical circuitry, transferrin power lines into a high speed network without new wires or drilling, and PLA5206 brings you a whole new large bandwidth to enjoy multiple HD streaming, online gaming and other network applications simultaneously in every room.
Features:
- HomePlug AV2 compliant with up to 1000 Mbps* data transfer rates
- No extra wires or configuration required
- Perfect for connecting Smart TVs and on-line games
- QoS ensures network quality for VoIP, IPTV & HD media streaming
- Single push-and-secure button for simple, fast security setup
- Compliant with IEEE 1901 and HomePlug AV technology
- Multi-color LED indicates powerline network quality
- Energy-saving feature offers efficient power management and cost savings
Benefits:
HomePlug AV2 integrated with Gigabit LAN connection With advanced HomePlug AV2 technology, the ZyXEL PLA5206 achieves speeds of up to 1000 Mbps*, which is a 30% increase in performance over a 600 Mbps* powerline and double that of a 500 Mbps* Fast Ethernet Adapter. The device also offers backwards compatibility with HomePlug AV and IEEE 1901 based products. In addition, the PLA5206 is equipped with a Gigabit Ethernet port.
The PLA5206 users can experience stable high-performance networking, including simultaneous HD streaming, online gaming and web browsing.
No extra wires or configuration required:
The ZyXEL PLA5206 lets you create a network using your home’s existing electrical wires easily extending Internet connectivity throughout the building while eliminating the need to drill through walls or install additional network cables. Forget about complicated setup procedures; no configuration is required. Just plug your PLA5206 into a power outlet and create a completely functional network.
Perfect for connecting smart TVs and playing on-line games:
The ZyXEL PLA5206 provides speeds of up to 1000 Mbps*, accelerating network applications like HDTV, multimedia HD streaming and online gaming. Users can easily transmit multiple HD streams and even 3D movies to every room quickly and smoothly.
Specification:
Standard:
- Compliant with HomePlug AV2
- IEEE 1901 and HomePlug AV standard
Powerline Data Rate:
- Transmit: up to 1000 Mbps*
- Receive: up to 1000 Mbps*
- Access Methods - CSMA/CA channel-access schemes
- Range Max.- range up to 300 meters over power line
- Power Saving Mode - When there is no Ethernet link in 60 seconds
- Security - 128-bit AES encryption
Quality of Service (QoS):
- ToS
- Supports up to 4-level type QoS
- Support up to 8-level VLAN priority field
- Frequency Band - 2 MHz to 86 MHz
- IGMP - IGMP v1/v2/v3
Physical Specifications:
- Item dimensions (WxDxH): 61 x 93 x 32 mm (2.4" x 3.66" x 1.26")
- Item weight: 100 g (0.22 lb.)
- Packing dimensions (WxDxH): 151 x 176 x 85 mm (5.94" x 6.92" x 3.34")
- Packing weight: 360 g (0.79 lb.)
Only £41.99 inc VAT.
ORDER NOW
ZyXEL 1200Mbps MIMO Powerline Gigabit Ethernet Adaptor Twin Pack @ £79.99 inc VAT
The ZyXEL PLA5405 1200 Mbps Powerline Gigabit Ethernet Adapter is based on the latest HomePlug AV2 standard and features data transfer rates of up to 1200 Mbps*. The Powerline adapter plugs into an existing power outlet and instantly enables high-speed network access through a home’s electrical lines. The device offers a perfect solution for streaming HD movies, Playing online games and enjoying other network-intensive applications—all without the hassle of installing cables throughout the residence. Featuring the latest HomePlug AV2 MIMO** technology, the PLA5405 utilizes multiple lines from your home’s existing electrical wiring, whereas non-MIMO based HomePlug AV technology uses a single line. This enables the PLA5405 adapter to perform at
up to twice the speed of existing 600 Mbps* Powerline products.
Features:
- The HomePlug AV2 standard creates powerline networks with data transfer rates of up to 1200 Mbps*
- Enjoy high-speed networking and complete coverage through Line-Natural/Line-Ground MIMO** technology
- Perfect for connecting smart TVs and playing online games
- QoS enhances media streaming quality
- Single push-and-secure button for easy security setup
- TR-069 support for remote management and automatic configuration update
Benefits
Enjoy high-speed networking and increased coverage through MIMO capabilities**
With advanced HomePlug AV2 technology, the ZyXEL PLA5405 provides users with steady, high-speeddata transfer rates of up to 1200 Mbps* and is backward compatible with HomePlug AV and IEEE 1901 based products. The new HomePlug AV2 Multiple Input Multiple Output (MIMO) feature increases throughput and coverage. The PLA5405 extends your home connectivity range by up to 80% using all three electrical wires—line, neutral and ground. The device connects your entire home entertainment network, making it the perfect choice for users who wish to enjoy HDTV and multimedia streaming to every room.
No additional wires or configuration required
The ZyXEL PLA5405 creates a network by piggybacking on your home’s existing electrical wiring system, easily extending your Internet around your home via a simple connection to a power outlet. There’s no need to drill through walls or lay new network cabling. No configuration is required. Simply connect your PC to a PLA5405 and plug it into a power outlet. You’ve now created a super-fast, secure and dependable home network.
Specifications:
Standard:
Powerline Data Rate
- Transmit: up to 1200 Mbps*
- Receive: up to 1200 Mbps*
Access Methods
Range
- Max. range up to 300 meters over power line
Power Saving Mode
Security
- ToS
Frequency Band
- 2 ~ 86 MHz
Dynamic Neighbor Network Support
- IGMP
- IGMP v1/v2/v3
- Item dimensions (WxDxH): 93 x 63 x 27 mm (3.66" x 2.48" x 1.06")
- Item weight: 95 g (0.21 lb.)
- Packing weight: 355 g (0.78 lb.)
ORDER NOW
TP-Link 300Mbps AV500 Wi-Fi Powerline Extender @ £33.95 inc VAT
TP-LINK’s TL-WPA4220 extends your Internet connection to every room of the house through your home’s existing electrical circuitry. The TL-WPA4220 features a Wi-Fi Clone Button enabling Super Range Extension, which means it can automatically copy the SSID and Password of your router. In this way, TL-WPA4220 simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
Features:
-One Touch Super Range Extension - Wi-Fi Clone Button simplifies your Wi-Fi configuration and helps build a seamless unified home network
-HomePlug AV standard providing up to 500Mbps1 high speed data transmission over a home’s existing electrical wiring, ideal for lag-free HD or 3D video streaming and online gaming
-Extend 300Mbps wireless connections to previously hard-to-reach areas of your home and office
- Add device to current TP-Link Powerline setup.
Up to 500Mbps - Ideal for HD Video Streaming
With advanced HomePlug AV technology, TL-WPA4220 provides you with stable, high-speed data transfer rates of up to 500Mbps on a line length of up to 300 meters. It is a great choice for a whole home solution to connect all network compatible devices--from computers, game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Extend Wi-Fi Coverage to Every Room
With wireless speeds of up to 300Mbps, you can effortlessly extend your Wi-Fi network via the existing powerline and broadcast a wireless signal to share with all your Wi-Fi enabled devices in another area of your home or office.
With a Wi-Fi Clone Button enabling Super Range Extension, the TL-WPA4220 can automatically copy the wireless network name (SSID) and Password of your router at the push of a button. After the pressing the button, you can place the powerline adapter anywhere you want wired or wireless access and enjoy seamless networking across your entire home or office.
Plug and Play
1. Plug one Internet connected adapter into a nearby power outlet. 2. Connect additional adapters to PCs/laptops/Internet TVs or other networked devices via an Ethernet cable or Wi-Fi - and you're done! *Recommended: Press the pair buttons for network security and data encryption. Note: Powerline adapters should be deployed on the same circuit and in set of two or more.
Specification:
-Standards and Protocols - HomePlug AV, IEEE802.3, IEEE802.3u, IEEE802.11b/g/n
-Interface - 2*10/100Mbps Ethernet Port
-Button - Pair, Reset, Wi-Fi/Wi-Fi Clone
-Range - 300 Meters over electrical circuit
-Frequency - 2.4-2.4835GHz
Signal:
-11n: Up to 300Mbps(dynamic)
-11g: Up to 54Mbps(dynamic)
-11b: Up to 11Mbps(dynamic)
Wireless Security - 64/128-bit WEP / WPA / WPA2,WPA-PSK / WPA2-PSK
-Dimensions ( W x D x H ) - 3.7 x 2.1 x 1.6 in. (94×54×40mm)
Only £33.95 inc VAT.
ORDER NOW
View our entire Powerline Range here
I have a tp-link kit, one standard unit, one with WiFi. I've been very, very impressed with it. If it affects my latency on the Xbox, it's to an unnoticeable level.
But then all my gear (except the VM router) is tp-link now.
A friend needs some of these but would need powerline running into two seperate rooms, is this possible with one main plug into the hub and two seperate ones in different rooms?
Yes you can, you can buy a twin pack and then a single and they will link together. I'm not too sure on the maximum you can use but I know that will work.
Only on the dynamode at the moment I'm currently looking at the TP-link models so if you know which powerline kit you would like I can look into it. Could always make it 4 rooms :). TP-LINK have limited single units but they will be listed shortly.
I couldn't say for sure as it would depend on how much he wanted to spend and if certain features were wanted. May just end up getting a twin pack to start with to make sure it all works well.
Also, I don't have a clue what brands are meant to be good when it comes to powerline.
Purchased a cheap make from here years ago,they were superb,never ever dropped out and gave me outstanding speed,these powerlines are really really good.
TP-link seems to be the favored choice and the selection is vast that's why I tried to narrow them down a little.
I have a few colleagues who have bought the dynamode and have yet to have problems with them.
I will be listing the single ones shortly anyway.
I would recommend one of the TP-LINK starter kits as they are very easy to setup and not that expensive to try.
I have 4 TP-Links, they sync anything upto 130 Mbps at my house.
99.9% of the time they are great, but occasionally they can get out of sync and they loose connection to each other. Still far better then Wi-Fi
How do the 500Mbps units operate at anything like that speed if they use only a 10/100Mbps Switch Port?
TP-Link are scum with their marketing. Even their gigabit switches are a falsehood because you can't transmit that on wires.
I've got 500mpbs adaptors with gigabit ports and can transfer well above what a 100mbps port would allow. Max is over 20MBps which is 160 Mbps.
Mine have a gigabit port, they're DLink adaptors - I was answering the post a couple up about whether a 100mbps port would limit the real world throughput of a 500mbps homeplug - it will.
Thanks all. I was referring to the TP Link 500 Mbps and Dynamode 500 Mbps units which both have 10/100 Mbps network ports.
The spec seems poorly considered even misleading.
