Hi folks,
Been a while since I did anything with a computer so just looking for reassurance that what I have done is correct.
My machine is old..
Motherboard : intel g965 socket 775
CPU Intel core 2 duo quad core q6600 kentsfield revision b3
X4 2tb wd green caviar HDDs fitted
Nvidia geforce 8400gs graphics card
Had it approx a year and the bios battery was flat and wouldn't save bios settings or clock within the operating system. I simply weren't fussed as it booted past that and I just manually updated the clock whenever the machine was powered down.
I have recently fitted the new hard drives above and fitted a cooler master mwe 80 white 500w PSU
4x new ddr2 ram sticks fitted
I replaced the bios battery but it doesn't appear to save settings so is acting like the battery is flat but it isn't having checked it with a multi meter and the battery is inserted correctly.
My voltages below: are they okay and safe?
Vcore1: 1.23v
Vcore2: 1.84v
+3.3: 3.31v
+5v: 4.97v
+12v :11.97v
-12v: 11.13v
-5v: 5.01v
+5v: 5.05v
Vbat: 4.08v
The above voltages are at 100% CPU load but remain the same at idle.
Thanks in advance
Rob
My machine is old..
Vcore1: 1.23v
Vcore2: 1.84v
+3.3: 3.31v
+5v: 4.97v
+12v :11.97v
-12v: 11.13v
-5v: 5.01v
+5v: 5.05v
Vbat: 4.08v
Thanks in advance
Rob
