Hi guys
I've built dozens of PC's over the years, but this one has really stumped me. Any help or advice massively appreciated
The system:
Intel i3 [email protected]
8Gb ddr3 1333mhz RAM
Gigabyte GA-H61M-S2PV
1Tb sata HDD
HD7770 GPU
500w Corsair PSU
in a crappy CiT vantage case
Windows 7
The upgrade:
New case - Corsair Carbide 200r
250Gb SSD
NVidia GTX950 2Gb
550w Corsair PSU
I chose the parts quite carefully and thought this GPU was about the most I could get away with before upgrading the mobo/cpu. The PSU upgrade was probably a waste of time, for some reason I thought it only had a 400w in it.
I dismantled the old one and rebuilt it into the new case with the new parts, seemed to go fine.
On first boot - It seemed to get stuck on the Gigabyte splash screen for a long time(usually it disappears after a second), then went into windows. I went into disk manager and found the SSD and formatted/partitioned it.
I was a bit unsure here how best to proceed, so tried to install windows to the SSD - this went through the motions and restarted, but on restart just stuck on the splash screen and then after a minute went to a black screen with a blinking cursor only.
I restarted and couldn't get into the BIOS or boot menu no matter what I tapped on the keyboard - I did this dozens of times, tapping DEL / F8 etc but same every time.
I tried unplugging each boot device and restarting each time to see if it would boot from the DVD / existing HDD / New SSD, but again - exactly the same thing: mobo splash screen for ages, and then black screen.
The inability to access the boot menu or BIOS was very frustrating - I had the idea that a PS2 keyboard might work so went out to get one - same problem.
I removed the CMOS battery for an hour, still the same.
Removed and reseated all RAM sticks
I even wondered if it could be PSU related, so removed the 500 and put the 550 in (I wanted to send it back and recover the £70 ideally)
Thats where I'm up to - This has really flipped my noodle, can anyone offer any advice of what to try next ?
Cheers
The system:
1Tb sata HDD
HD7770 GPU
500w Corsair PSU
Windows 7
The upgrade:
250Gb SSD
NVidia GTX950 2Gb
550w Corsair PSU
Cheers
