Permabanned
- 19 Dec 2005
I have 2 IDE Hard drives, one with Windows XP and the other with Linux installed on, both linked together using GRUB, and both OS's worked fine.
Anyway I upgraded my system by installing a new motherboard, cpu, ram and graphics card.
The computer recognises both the operating systems, but when i try and load Windows, it will flash a blue screen with what appears to be white writing on it for less than half a second, and then restarts the computer.
I've tried booting into safe mode, and safe mode with CMD prompt, but again the computer just restarts itself.
I can boot into Linux but am having trouble connecitng the the internet, and am tempted to just start fresh and format my HDD and start all over again.
Is this advisable or might there be a more sensible solution to my problems?
The other problem is that of course if I can't boot into the CMD prompt through safe mode, how will I be able to reformat the disc?
Could I do this by using the WinXP startup disc?
Thanks for any assistance.
