Upgrades for bf3
1 Jul 2009
Time to upgrade again. I need a new gfx card to replace my zotac 285 for battlefield 3 I would like to run it on ultra settings @ 1920x1080. I am running an i7 920 @ 4.1ghz with a gigabyte ud5 and 6gb ram.
I would also like to upgrade my ssd I have a corsair Reactor 60GB (CSSD-R 60GB2-BRKT) which performs great but I find its not big enough so I need a 120gb at least.
I have about 650 to spend
Any advice or suggestions.would be great thanks
For SSD look at a Crucial M4, either 128 or 256 depending on how much you want
For gfx Id recommend you either go a single 580 or if youre not too bothered about heat/noise you could go dual cards, eg 2 570s or for ATi 2 6950s, though make sure your PSU is upto it
The m4 is a sata 3 drive isnt it? would it be worth paying the extra for that drive when I'm only on sata 2 or would the corsair series 3 be as good?
Noise and heat is an issue for me so I was thinking of getting the msi lightning 3gb card but is this the best way to spend 550?
I'd go for the M4, then if you do upgrade your mobo you can make use of SATA III. It will still be fast on SATA II.
Personally I wouldn't go for that card, it's very expensive for a single card. If you're only running at 1080p then a regular 580 should be fine. Though I don't know! Someone else will know more...
Thanks marius thats an intetesting post comparing 1.5gb and 3gb cards.
The 2 ati cards is certantly a cheaper option but I think it would get very hot in there and adding extra fans would be too noisy.
I think I will have a look at 1.5gb 580's thanks
A single 580 isn't enough for bf3 at that resolution. I am on a mixture of high and ulta and it still looks beautiful. I like to have a high minimum framerate and with these settings I get a pretty constant 60fps. If you want everything on ultra with max aa/af either get a 590 or look at the sli/crossfire options.
Thanks for the reply, thats put another spanner in the works so I guess dual 6950s or 6970s is the best way if I want to run ultra?
