- 23 Jun 2007
Hi All,
Been spending a little time hanging round and observing on the forum, plenty of knowledge here it seems.
Looking to upgade my old self-build (still don't believe I managed to build it and have NEVER had any problems
) but not sure where to start. Last time I took the spec of a decent PC from a local specialist, bought the parts and built it myself, because I wanted to.
So, currently sitting inside a 400w PSU case are the following;
ASUS A7V8X-X Motherboard Socket A
Athlon 2200 Processor (shows 1800Mhz in system info)
Kingston 512Mb 333Mhz DDR PC2700 RAM
ASUS V9520 Magic 128Mb Graphics Card
Hard Drive is 40Gb (can't recall spec and not there right now)
OS is Windows 98 with official XP Professional Upgrade
Basically looking to spend a small amount in order to get her playing MS Flight Simulator 2004 at a reasonable speed. I have taken the 1st step and gotten hold of another 1Gb of RAM, identical in all respects to my current stick but 1GB. So that will multiply my RAM by 3 for starters when it arrives.
Thinking about processor and graphics card updates then but basically not sure what is worth doing whilst sticking with current system otherwise. There is a review of my motherboard somewhere on this site so any info that means something to people (but NOT me....) is around nearby.
Any help greatly appreciated but please remember limited budget as a few other commitments right now.
) but not sure where to start. Last time I took the spec of a decent PC from a local specialist, bought the parts and built it myself, because I wanted to.So, currently sitting inside a 400w PSU case are the following;
