Some 5 years ago I bought a system off OC (attached) and have been very pleased ever since - touching the proverbial wood. The only upgrade I have done is to install another SSD drive primarily for gaming. The machine still works really well for most applications I can throw at it.
I'm now in the market either for an total system upgrade or a new GPU although I suspect I will be more likely to go for the former. I've also got to the stage in life where I don't really keep up with hardware trends relying on others to suggest things based on their own experience.
Since retiring I mostly program applications (Visual Studio) for a business I own and also spend a long time rendering video footage I have shot with the occasional sedate gaming (e.g. FlightSim, no shoot 'em up) and general applications. I have worked in an IT related sphere casually since late 70s and know my way around most things.
It is the now the speed of video rendering (using Vegas Pro 15) that is slowing things down because Nvidia removed CUDA capability from its drivers. I have read that if I could use a later model NVIDIA card then would decrease timings dramatically by using the NVEC encoding capability which is not supported by the GTX580.
So before I talk to OC, a fundamental question has to be is it worthwhile my while installing just a new GPU (and if so what is recommended) in the existing hardware (assuming it is compatible) or would I be better off purchasing new. On basis of what I paid last time I am expecting a new system price of up to about £3K. If I go for new the old system I can use as a secondary system to provide network input to applications such as FlightSim so would not be wasted.
Thanks - John
"Ultima Tyrannosaur" Intel Core i7 2600K 3.40GHz @ 4.60GHz
DDR3 Sandybridge System
SW-131-MS Windows 7 Ultimate 64 bit OEM
XX-050-XX No SLI Upgrade
MY-290-CS 16GB DDR3 Memory Upgrade
FS-183-OE Overclock Selected
MY-290-CS Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual
Channel Kit (CMX8GX3M2A1600C9)
FG-062-AK Akasa AK-FN055 Quiet Pearl White 120mm Fan - 3 Pin
HS-003-CS Corsair Hydro H70 High-Performance CPU WaterCooler (Socket
LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3)
CD-138-SA Samsung SH-B123L/RSBP 12x BluRay ROM DVDRW DL & RAM
Lightscribe SATAII Optical Drive - Black (Retail)
CA-028-CS Corsair Professional Series™ Gold AX850 High Performance 850W
Power Supply (CMPSU-850AXUK)
CA-165-AN Antec 1200 Twelve Hundred (V3 with USB3.0) Ultimate Gaming
Case - Black
CP-365-IN Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155
Processor - OEM
GX-141-GW Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5
PCI-Express Graphics Card
MB-342-GI Gigabyte Z68X-UD3P Intel Z68 (Socket 1155) DDR3 Motherboard
HD-368-WD Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM
(WD2002FAEX)
(WD2002FAEX)
HD-048-OC OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive
(OCZSSD2-2VTXE120G)
Thanks - John
