Hi there
I have an old computer, and want to upgrade the CPU.
The computer is an eMachines E3038.
Motherboard:
- Intel® D101GGC
Click for More Info
Current CPU:
- Intel(R) Celeron(R) D CPU 3.20GHz
The CPU i want to replace it with:
- Intel Pentium D 3.60GHz (found a couple on ebay to check all the specs)
I've checked the socket type and it seems to be compatible (LGA 775), the same goes for the system bus speed (800Mhz).
Are those two things the only things you have to check when checking compatibility between processors and motherboards in general?
Also the new PU is dual-core and has '64-bit Instruction Set Support' when the old CPU does not? Does this affect the existing operating system installed on that computer (which is 32-bit)?
Do you guys the upgrade is worth it? I've looked on http://www.cpubenchmark.net/cpu_list.php and the score they've given it is almost three times as good as the old CPU. I'm just looking for a general increase in speed so i can run some newer software on it
Thanks in advance
Motherboard:
- Intel® D101GGC
Click for More Info
Current CPU:
Thanks in advance
