Upgrading an 8 year old system for video editing / media
16 Jun 2011
My home-built PC is getting quite slow doing the media-heavy tasks (audio and video production) which I do every day.
I was tempted to get a new processor, but my motherboard can only support up to the i7-7700K which is slower than much cheaper modern processors. Is it time for a complete new rig, or are there parts of this one I can salvage?
  • MSI H110M Motherboard
  • i5 6500 @ 3.20GHz
  • 16GB DDR4 3000MHz RAM
  • GIGABYTE GeForce GTX 1660 SUPER
  • EVGA 430W PSU
  • Corsair 88R case
  • 1TB and 250GB SSDs
The i7-7700K would likely be a nice boost if your video work is heavily multithreaded, but their cost rarely justifies it compared to a ~£70 5500/12100F, or a ~£100 i5-12400F/Ryzen 5600.
If you don't mind having a go at modding, you could try loading a modded BIOS for the 8th/9th gen CPUs, since something like a i5-8400 wouldn't be a bad improvement for ~£30.
Do you have a budget? You could pick up a cheap A320 and (if BIOS allows) whack a 5000 series CPU in there and reuse your RAM for not much. 7700Ks seems to be going for £100 still!
If it will get me good improvements, I'm happy to spend up to maybe £600-800 or so. Of course if I can get a lot of improvement by spending more like £200-300, that would be preferable.
Certainly happy to get a new mobo — it's been a long time since I built a system, am I right in saying that a A320 mobo would fit in my case / work with my RAM and GPU? Would also be keen to expand storage with an M.2 drive so this could kill two birds with one stone.
It'd work fine, it's budget end AM4 so I was really using it for an example, you might want to buy a better one with that budget though.
Not sure what your case is but assuming it'll take an mATX as I think the H110M is?..
I reckon you can easily buy a motherboard, 5000 series CPU and some more storage for £200 (Mobo ~ £50, storage ~ £50 leaving £100 for CPU). Not easy to buy new really, OCUK only have B550 boards for ~ £100 and I'd personally not pay that much for AM4. If you want to spend £600-£800 you'll get a decent platform upgrade but then you need to consider new PSU etc too.
Do remember that it's sort of a dead end platform now though, you've got your 5800X3D for gaming as top end, and the higher core count CPUs still aren't exactly 'cheap' so you could upgrade to a low end now, then to a better chip later on, or do the whole thing now.
2nd hand you might be able to get a mobo/CPU bundle with a 5800X/5900X (over £200 though) which would destroy your 6500
I'd suggest something like this as a middle ground, which would get on a new platform with future CPU upgrades.
My basket at OcUK:
Total: £468.88 (includes delivery: £0.00)​
Intel alternative to keep your memory, I'd strongly recommend you avoid 13th-14th gen until we know they are fixed:
My basket at OcUK:
Total: £341.93 (includes delivery: £0.00)​
Bye, bye budget option:
My basket at OcUK:
Total: £742.96 (includes delivery: £7.99)​
Some numbers:
CPU: single thread, multi thread
i5-6500: 2109, 5626
Ryzen 5 7600: 3915, 27128
i5-12600K: 3950, 27719
Ryzen 9 7900 4152, 48868
I'd recommend waiting until the Ryzen 9000 CPUs release in August, if you're going to buy into AM5 and/or blow the whole budget.
Hi all! Thanks for all the above responses. Sorry to resurrect this thread - I got silly busy with work and parked this, but am now looking to get parts on order today / tomorrow.
I'm leaning towards something like the second option above - keeping my memory (perhaps adding another 2 x 8GB for about £30) and sticking with Intel. Am I right in saying that 14th gen Intel is now fixed, so I could go with something like the below? Is this still a reasonably cost-efficient plan?
My basket at OcUK:
Total: £419.95 (includes delivery: £7.99)​
(My current RAM is the 3000MHz version of the above, not available on OcUK. Am I right in saying that I can add the 3600MHz with no issues, except it will all run at 3000MHz?)
This is always a gamble to mix sticks, it might work, it might not. The safest option is to sell the old kit and replace with 16x2.
Intel says yes, community says: ???
Personally, I'd stick with 12th gen if you're coming from an i5-6500, unless you're happy to trust their 5 year extended warranty (on 13th-14th K CPUs) will see you through.
Go with the 14th gen. Intel have a long long warranty. If there are any issues (unlikely) then just replace it - like I am doing.
ryzen 2700 or 3700, am4 b450 motherboard and 32gb ram. all you would need and you can get the board and ram new for a good price. im not sure how much those ryzens are going for new, but i bet 2nd hand will be better value. can easily achieve that combo for under 200 quid
