My Antec is slightly faulty as the power button doesn't do anything and the reset button IS the power button. If you know what I mean..? I think that may be because I tried opening the top part of the case when I got it but that was before I had ever turned it on so I can't be sure it wasn't like that when I brought it. Also, I find it really inconvinient to clean the fans and it collects dust really easily which is also hard to wipe off of the matt surface which has many groves and hard-to-reach places. I also don't like the fact that the 120mm fan on the top doesn't have a filter so dust can easily enter the case and reach the components. I would appreciate it if anybody could tell me how to FULLY open the case so I can try to fix the problems.
For these reasons I have been looking to buy a new case. Any suggestions? I've been looking at the Thermaltake Level 10 GT, anyone have have this case and/or would you recommend it?
Thank you for contributing in advance
Then again, I don't feel the 902 is the world's most interesting case...
