I have a Gigabyte GA-P35-DS3R board with an E2160 1.8ghz overclocked to 2.4ghz running fine on stock cooling, I have had it up to 3ghz but it was getting a little hot.
I have a Gigabyte 4850 1GB Graphics card and 4GB of Corsair TwinX DDR2 8500, only 3GB seen under XP Pro SP3
So I think the CPU is the weekest part of my setup
Currently I want to improve my performance playing GTA4 wich apparently
needs more than 3 cores to run to its fullest so I think I need to go to a Quad core.
Was looking at the Q6600 but can now get a Q6700 for similar money but it seems that the Q6600 is a good one to OC.
What CPU is going to give me best bang for buck for around the £150 mark?
Also do you think it's worth changing to Vista at the same time as upgrading the cpu?
Cheers
Cheers
