Hi guys.
A friend of mine in my COD4 team is looking to upgrade his OEM PC (HP Pavilion a6635uk), as it is now struggling to play CoD4 at enough FPS.
Specs are in the link above and, as you can see, there is a PCI Express 16x slot which will fit a decent GPU. The problem of course is the PSU. What I used to do in the past, was recommend the ATI HD 4670 as it was about the most powerful card that took all the power from the motherboard.
Now, he probably could pick one up second hand, but he has £100 to spend. Question is, for that much, what is the best card that will do a similar job the 4670 so that the PSU need not be upgraded? However, if is possible, I was thinking that he may be able to get a decent branded 400W PSU or something for under £40, and then spend the rest on something that requires a PCI-E power connector.
All advice is appreciated greatly. Thanks guys.
