- 21 Jan 2010
- Wales
Planing to upgrade a general use pc
some light gaming general faffing about.
spec:
2.4GHz Intel Core 2 quad
2GB DDR2 RAM
Pci Express nVidia GeForce 8400 GS
sata 500gb segate
Windows Vista 32bit
think its a 300w psu
Not sure on the mobo as im not with the pc atm.
the system is an (iMax 3414)
Space is very very tight inside!
so much so i doubt i could find another gfx card or psu to fit it
about 2cm gap from the hdd with current nVida 8400gs
have allso thought about taking it all out and getting a better case
but it seems the body of the case will not allow room
for the mobo to come out. 0_o
ill try and get a pic up soon if any ones interested.
But for now i have thought about bits i can do...
_________________________________________________________________
Microsoft Windows 7 Home Premium 64-Bit
Kingston HyperX 4GB (2x2GB) DDR2 6400C5 800MHz Dual Channel
Edimax EW-7727In nMax 300Mbps Wireless Desktop PCI Network Adapter
any other ideas guys ?
think im missing something etc...
Cheers!
spec:
2GB DDR2 RAM
sata 500gb segate
Windows Vista 32bit
Cheers!
