Upgrading and have a couple of questions
16 Jan 2012
So my current system is over 4 years old now so its time to look at upgrading
Im thinking of ordering the following Mobo/Cpu bundle
https://www.overclockers.co.uk/giga...rboard-bundle-20-pounds-saving-bu-022-gi.html
and i'll add on 16GB DDR4 Ram.
I already have a Gigabyte GeForce GTX 970 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card so i think graphics im pretty alright still?
Now my questions is - with this mobo bundle, im struggling to find a fan cooler (Not looking to water cool) that fits the motherboard - Is Socket 1151 the same size as say 1150 / 1155 etc?
Also what PSU would be recommended?
I dont want to go overboard with costs but im currently using a XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply and im unsure if it'll be enough to power the system
Anyway much thanks :)
Russell
Your psu is more than enough so that won't need replacing. Exactly what motherboard and cpu do you have currently. If it's a 2500k or later then we usually advise to overclock it if it's not already clocked as it's still a very capable cpu. Intel has given us very little in terms of performance increases since Sandybridge was released and has instead focused on igpu performance and power efficiency.
Currently using a 590i Intel Core i5 2500K 3.30GHz , it was overclocked to 4.40GHz (Bought as a pre overclocked bundle from here 4 years ago)
My biggest issue is now that i have Fibre optic broadband (Its taken ages to get here, i live in the middle of the scottish borders), i have a 80mb down and 20mb up line, and streaming should be pretty good quality, but OBS and whatever game im playing is causing my CPU usage to go to 100% - hence the looking for a new cpu etc
There has been minimal improvements in cpu performance in the last four years. I suspect what you have is already good enough.
Edit: just see you have a 2500k. Just make sure it's over clocked to a decent level and its pretty much as good as any new cpu.
No idea why your broadband would cause any cpu issues. Try an os reinstall.
not the broadband causing cpu issues , but for example last night i was streaming Rocket League using OBS.
OBS was using around 50% Cpu and rocket league the other 50%
OS refresh and format my HDD is maybe a shout though - been needing to do that for a little while (and at leasr i can download my games a fair bit quicker!)
Thanks for the advice guys
