Upgrading and need help!
16 Mar 2013
Hey guys,Thinking of Buying a Intel Core i7-4790K 4.00GHz (Devil's Canyon) but as I use AMD Iam not too sure on what motherboard to buy with it.Also will I be able to use the Corsair Hydro H100i on it?
Well the gigabyte z87 oc force is 199 and it is compatible with the 4790k
What are the rest of your system specs
Bu 019 as
Bu 012g1
Mb 478g1
Type these codes in the seach box
At the moment i have:
Sapphire HD 7950 3GB GDDR5 with Boost
AMD FX-4100 3.60 GHz
ocz zs series 650
ASUS M5A 78L-M LX
4gb Ram - Will get 16gb
The i7 4790k is meant for overclocking as it is unlocked. Seeing as you want a H100i, you might as well give yourself the option to overclock in the future. Just get any Z97 board that takes your fancy :) or go for one of the motherboard bundles.
