Hi all,
Just looking for some advice as I've been out of the loop so long (this unit was built in 2006 and has been topped up in between). I don't think there is much that can be salvaged but would love to know peoples thoughts.
Budget wise not really looking to set limits but I am a tight wad
I'd like something that is fit for purpose rather than necessarily setting the world on fire. The rig can be built over a period of several months as well. I think the critical area to get right is the mobo, CPU and ram at this point.
Gaming will not be on the list of requirements. Purpose of the machine at the moment is to run esx, workstation and a ton of virtual machines. I also use it to maintain and run a business from which requires a lot of basic video editing. Its more volume than quality.
Current equipment is as follows
MSI N1996 AM2 board with a lowly x2 5600+
4GB PC2-6400 ram
2 x 320GB Hitachi deathstars in RAID 0
1 x 500GB seagate as a data drive
Backing up to an external USB drive currently.
EVGA 8800GTS card its the cut down version with 768mb from memory
The power supply might be salvagable ? its a hiper type-m 670W
The case is made out of Meccanno and best forgotten.
Screen, keyboard etc I can carry over also.
Many thanks in advance, appreciate she is old but in all honesty she's only just starting to show her age and mainly in the speed of the CPU and disk access. (running multiple vm's batters storage
I'd like something that is fit for purpose rather than necessarily setting the world on fire. The rig can be built over a period of several months as well. I think the critical area to get right is the mobo, CPU and ram at this point.Gaming will not be on the list of requirements. Purpose of the machine at the moment is to run esx, workstation and a ton of virtual machines. I also use it to maintain and run a business from which requires a lot of basic video editing. Its more volume than quality.
4GB PC2-6400 ram
Raid 10 or 50 one day when I get a lotto win
