- 1 Sep 2014
Well my brother bought a HP Pc a while ago for ~£1000, not the best spec for around the £1000 mark I know.
I am looking to upgrade the GPU for him so he can play higher end games etc... this is his spec: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c03983810
I was looking at doing sli then noticed the board can't do it.... so was looking at something like the gtx 770 but not sure on what it will be like for power consumption, I haven't worked it out yet, but I am imaging it not to be the best "/...
So turning to you guys to give a helping hand on options
Also what would it be like clocking on this board, is it worth it? I know the I7 4770 (not sure is his is the k or not) is not a bad cpu anyway just thinking if push comes to it
It should only be the GPU holding him back right?
