Upgrading CPU (Q6600 and/or E6300 need help)
Orm
Orm
10 Jan 2006
I have a Q6600 quad core in my machine and my wife is running one of the old core 2 duo E6300's (1.6Ghz default speed).
While i'm happy with my machine, her's is starting to look a little long in the tooth - i've upgraded her memory (4 Gig of Ballistix 6400), graphics card (8800GT), so it's a pretty obvious bet the CPU is slowing her down.
So the question is, do I buy her a E5300 (http://www.overclockers.co.uk/showproduct.php?prodid=CP-273-IN&groupid=701&catid=6&subcat=793) £70 that i've heard rave reviews about and apparently overclocks madly or E7400 (http://www.overclockers.co.uk/showproduct.php?prodid=CP-271-IN&groupid=701&catid=6&subcat=793) £106 OR do I upgrade my cpu to either E7500 (http://www.overclockers.co.uk/showproduct.php?prodid=CP-193-IN&groupid=701&catid=6&subcat=793) £173 or Q9400 (http://www.overclockers.co.uk/showproduct.php?prodid=CP-270-IN&groupid=701&catid=6&subcat=567) £191??
Which is likely to yield the best performance boosts etc ?
the quad vs. duel depends on what she uses the computer for, and it depends if you'll overclock it on not.
personally i''d pick a Q6600 as i just did and it's great for my needs.
What does she do for that to be too slow for her? :eek:
I'd just get an overclock on the cpu myself, you should easily see over 2ghz which will give some good performance gains.
She games, WoW and some cheesy arcade games :)
What kind of performance increase would the E5300 give her ?
Well you'd be able to get 3ghz+++ out of it depending on the cooler, so probably quite a bit. the cpu is definitely the limiting factor at the moment.
personally I'd have a go at overclocking first... because that's free.
