Upgrading for VR (Oculus Rift S)
17 Jul 2010
(Wasn't sure whether to post this here or in the VR forum)
So, having finally decided to go for the Oculus Rift S as opposed to the Quest, I need to get the PC sorted.
At the moment, I have a tower that is probably 6-7 years old and I'm not sure if I can do anything to this one that would handle the Rift S with ease. I understand the GPU is the most critical element for VR, so what do you guys think?
Current Spec:-
CPU: Intel Core i5 3570K IvyBridge
M/B: GigaByte Z77X-UD3H
RAM: 16GB Corsair Vengeance PC3-10700H
GFX: GeForce GTX 670
I haven't really thought about budget as I was hoping I wouldn't have to do a complete upgrade, which would pretty much amount to almost a new PC. If I can get away with a new GFX Card up to say, £200, would it be hindered by the other components?
Rig is not really used for any other desktop gaming; only coding these days.
Just having a quick look around. If I was to upgrade (using existing case/PSU/HDD), how would this look for supporting the RIFT S
My basket at Overclockers UK:
Total: £573.06 (includes shipping: £11.10)
drop ram to 16gb , 32gb still a bit overkill unless your rocking heavy mods on games like City Skylines
GTX 1660S is a nice bump in GPU power over 590 and less power required
Total: £535.06 (includes shipping: £11.10)
slightly more but more power!
ODE
Total: £615.06 (includes shipping: £11.10)
or
Total: £595.06 (includes shipping: £11.10)
5700 edges slightly with more VRam and higher FPS , but also higher power draw
another option is i7 K second hand £75-85 odd then sink £400 into RX5700 XT or RTX 2060S​
Not wanting to spend a fortune, I think I'll go with upgrading the GFX on the existing machine, but with the Gigabyte GeForce GTX 1660 SUPER OC 6144MB GDDR6 PCI-E rather than the RX590, as per your comment orbitalwalsh.
If I find the system struggling with that, I'll then either look to upgrade the CPU/MB/RAM or just upgrade existing I5 CPU for a s/h I7.
Thanks for your input guys.
*Help* :/
So, went ahead and plunged for the Gigabyte GeForce GTX1660 SUPER OC. Dropped it into existing system but now it won't boot :/ Fires up to board logo screen but unable to get into BIOS. Hangs there for 30 secs then goes dark, flashes a bit, goes dark again and hangs there. Tried another slot but same issue and error code on board is 62. Any ideas guys?
Rest of system is:-
PSU: CollerMaster Silent 700W
If I drop the old 670 in, boots fine, same if I boot from onboard GFX.
Thanks in advance
/sadface
*Help* :/
Rest of system is:-
Thanks in advance
/sadface
Update board bios
Ten be GPU and use onboard graphics from intel
V1.1 /1.2
https://www.gigabyte.com/uk/Motherboard/GA-Z77X-UD3H-rev-10/support#support-dl
Apologies. Missed your last post. Yes, BIOS update did work, but I think I'm going with a board/cpu/mem upgrade anyway, bring everything up to date. VR does run sweet on the 1660 GFX mind you, even with the rest of the older kit.
cheapest quickest way would be second hand i7k and overclock!
personally moving from i5k you'd want to double your cores to ryzen 3700 and triple the thread count. would last 5 years again
