Ok I've had my 560TI now for quite some time and it looks like it may finally need upgrading. It's been struggling with newer games, couple that with this whole mess with nvidia and the newest drivers has me still running on the 314.22 drivers as they were the last stable.
Currently running
Intel I5 2500k at 4.5ghz
8gb Ram
650watt OCZ ZS
AsusP8Z68-V/GEN3 Mobo
Do you think I'll need to upgrade the PSU? I know if i tried to overclock the GPU by even a small amount the pc would lock up. Same if I tried to take the CPU to 4.6ghz (This is the old Spinosaur build and it was never stable at 4.6ghz)
I'm looking at upgrading to something that will keep me for a couple of years again (hopefully) but I'm looking at a budget of about £200 for the card. Can you guys give any advice on card choices and if I need to change anything?
Thanks in advance
Currently running
8gb Ram
650watt OCZ ZS
Thanks in advance
