Upgrading from 5820k - c£600-700 for CPU/Mobo & prob RAM
16 Mar 2004
Surrey
My slightly venerable 5820k system died a few days ago so I'm looking for an upgrade bundle.
PC is only rarely used for gaming, but a fair amount of photo & video work (Photoshop/Premiere/Lightroom plus a bit of Davinci).
Existing RAM is 16gb DDR4 2400, so likely a bit slow and also possible it's faulty so will probably need to replace.
Case is full tower (some huge bequiet behemoth :) )
I'm at least 4 years out of date on specs, so fairly clueless ....
I saw a 3900x/x570 Auros/16gb Corsair bundle for £650, which seemed OK .
Any suggestions welcome - open to used via MM here as well.
Cheers
Thanks - looks like that mobo wont have enough internal sata ports, but at least the idea is in range :)
Any views on whether the 3900x is the best bet?
12 cores and plenty of ram should be big improvement but it mite worth looking at the 5800x as a price comparision . 4 less cores but higher single core ipc.
Check out benchmarks 3900x v 5800x in programnes you use .
Others may come along and chip in.
I would open a thread in cpu section of the forum 3900x v 5800x ? And list the programmes you use.
12 core 5900x is £500
