damn the 7990 still holding well cant even remotely justify the cost looking at those benchmarks
Depends what resolution you're at, for 1080p unless you're having issues I wouldn't bother.
Also, how much do you reckon I could get for my 7990? I don't have enough posts for the marketplace, so it would have to go on ebay.
I don't have Witcher 3 for PC, sorry. I'm really only playing FF14 atm, which means buying a new gpu would be a waste of money but I'm feeling that itch again.Recently I have been doing some research on this as well, somewhere between £150-£200 on the bay.
Also have you played Witcher 3 at 1440p? If so what fps / setting / any micro suttering?
I get micro sutter (only 30% gpu usage) when I use 1440p VSR on my 1080p monitor during combat (especially when I use the fire magic...)
If xfire works, ie good profile support thats not a bad shout mate. But there is the increased power draw, heat that you get from multi gpu with each vendor. Ive used a few sli setups over the years, and ill be the first to admit that it is never perfect. But i gotta say, since moving to a single 980ti from sli 780. The games im playing do run smoother, much lower noise and a card that runs cooler also helps to keep my cpu temps down a bit. Very good as tbh, an overclocked 4790k runs pretty toasty.I keep thinking about upgrading my 7970 to something new, but aside from the usual thoughts of going for a 980 / 980ti / 390X, I am tempted to just drop another 7970 in. Mind you, I'd need a new psu.
