Upgrading from a 2800+ to a 2500mobile
21 Oct 2002
IS it worth upgrading from a Athlon xp 2800+ (166fsb) to a 2500mobile (2.3ghx on air) for around a tenner?
Am I likely to see much dif? I thought the dif in bus speed and faster clock speed would make a fair difference?
Cheers
Only in benchmarks. You won't see any real-world difference and the 2500M at 2.3 may require noisier cooling than you have currently.
Completely not worth it IMHO does your 2800+ not clock at all?
Cheers
For a tenner, with that overclock you have to at least check it out!
id pay a tenner for it. spend a few hours tweaking it, if yu cant tell the difference, send it to the bay
I thought we were talking your chip + £10 if your just buying it for £10 then its well worth it
the magic word is fsb - unlocked multi on mobiles means you can get it as high as your board will allow - and this does make a difference in real world performance
You're likely to get a fair bit more out of a 25000-M than 2.3Ghz too if you have a decent board. I remember both of mine did 2.75Ghz but they were damn nice chips :)
punisher46 said:
whats the chances of running it 12*200 on an asus nf7 v2.0?
it should do it if it has decent cooling. mine is a 2600m but is considered to be a bad clocker since it only does 2.5ghz at 1.825v. a lot of the older xp-m cpus manage to do 2.5ghz at 1.75v being easier to manage on heat.
