Upgrading from a 5870
Ideally, find a 7950 as close to your budget and clock it, should give you the best margin your looking for at your budget.
There is the £200 7870XT(slightly chopped down Tahiti(79**) if that's the max you can spend, but the extra will get you a bit more grunt.
