Is it worth getting an 8700k from a 8600k? They go for around £130 but is it worth it? Some games i play require better CPU's and i do suffer with fps lag i'm currently using a 2070 super and 32GB ram so i do think it might be my bottleneck
You do need to give a bit more information to get a more definitive answer.Is it worth getting an 8700k from a 8600k? They go for around £130 but is it worth it? Some games i play require better CPU's and i do suffer with fps lag i'm currently using a 2070 super and 32GB ram so i do think it might be my bottleneck
I thought you might be along with some no nonsense advice.I'd just sell the kit, board/CPU/RAM and buy something much better while spending not much more, and will be a huge jump over 8th/9th Gen parts
12400/B660/32GB DDR5 for £410 less the £200 you'd get for your kit.
) AND ALSO you don't mind spending a bit of time tuning your system then I'd probably inclined to save myself £100 of that £200 and get the 9700K. The drop in CPU might be more straight forward as the new Alderlake might require a total reinstall if you're on Win10 and AL really is better with Win11 (even using a program like Process Lasso on Win10 is not as good as a fresh Win11 for Alderlake in my experience)If you want to find your bottleneck then run afterburner with GPU and CPU usage enabled in the display while playing, you will then find out whether it`s your CPU or GPU holding you back.Is it worth getting an 8700k from a 8600k? They go for around £130 but is it worth it? Some games i play require better CPU's and i do suffer with fps lag i'm currently using a 2070 super and 32GB ram so i do think it might be my bottleneck
Thanks. What about tuned CFL similar to what you had. I seem to remember your tuned CFL blowing people out of the water in the Fall Out game bench thread?ADL will have a major advantage over CFL-R. It's not close if games are the main goal. I'm asuming untuned as well on both platforms.
Re use ddr4, get whatever ADL cpu can afford. 12600k would be ideal if you can get one used but 12400f is fine also. Might be worth waiting for RPL to release and pick up a used ADL chip for those who might want to do a drop in upgrade.
