So currently im running a Sapphire r9 280x (triple fan) on a Dell U2412m which is 1200p i believe? It also all shoved into a Raijintek Styx case along with a Noctua Nh-D14
so as you can imagine its a really tight fit as the cooler is like the kraken. It sometimes hits around 70 degrees during CS:GO so am I better going with a reference/blower cooler? Also the cpu is a 4790k.
What is going to be a worthy upgrade GPU wise? I was looking at getting a gtx 1070ti second hand for a while but really tempted by the 5700 with cashback.
Cheers dudes
Cheers dudes
