Upgrading from FX 8350 to i5 6600k worth it?
14 Sep 2014
Northern Ireland
Hi guys, so the title says it all really. Is it worth me upgrading from an 8350 to an i5 6600k. I use my pc for everyday use and gaming, i dont edit etc. Obviously i would have to upgrade my board and ram aswell so was just wondering if its worth it all in the end.
Current build:
CPU: FX8350 @4.5ghz
Mobo: Asus Sabertooth 990fx
RAM: Crucial Tactical tracer 8GB
GPU: R9 280X
PSU: EVGA supernova 750w
OS: Windows 10
Thanks
It'll be a faster CPU for gaming, so not a terrible idea, though you'll more often than not be held back by your GPU I'd have thought.
Personally I'd either look for a new GPU instead or more likely wait till later in the year, see what the new GPUs are like then (Pascal/Polaris) and also hope Zen forces a price war on CPUs.
Yeah might not be a bad idea to wait and see what the new ranges are tbh. But the reason i wanted to change the CPU was because i play CPU intensive games such as arma/squad etc.
If games you currently play are suffering in performance then might be worth upgrading sooner :) in which case the 6600k is a nice step up for most games (I've no idea how threaded those games are so not sure how well a clocked 8350 would handle them). Have you looked at usage levels to make sure the CPU is holding the GPU back?
(With no framerate cap the GPU will fall down from near 100% to lower if CPU is holding it back)
My GPU can reach 100% load on certain games so not bottlenech as such
That means the GPU is bottlenecking your CPU, as the CPU has redundant capacity.
That board should push the 8350 to 4.8 without too much difficulty, then hold out for Zen. :)
No it aint bottlenecking, as you want 99-100% gpu usage, when i had my 8350 @4.8 i was running two 7950's @99% usage.
Yeah board would even do 5ghz but if the OP has not got the cooling, they cannot run it higher.
You'd see slightly better average fps I reckon but a new cpu, board and memory isn't worth doing for a 280x.
Comprehension fail.
Also, an FX8350 isn't pushing two 7950's at 99% as a blanket statement.
Yes it will with a game that has xfire support.
Have you had a 8350.
I don't need to have had an fx8350, to know that blanket statements are a fallacy.
You've literally made a statement that doesn't apply to all situations in the slightest. At 1080p, there will be a vast amount of games that simply don't run 99% on both gpu's on max settings in game.
I can accept some games may very well. In the same respect there are ones which don't.
Current build:
CPU: FX8350 @4.5ghz
GPU: R9 280X
OS: Windows 10
Thanks
Depends.
Do you play single core games like World of Tanks or many ancient ones? If so yes you will see difference even if you upgrade to an old 4770 (not even K model).
If you play current games only, and especially upcoming DX12 ones, no. Grab a R9 390 or stockpile the money for a big upgrade end of the year with Zen & Polaris.
