- 6 Oct 2012
- (do-or-die) Wye, Ashford, Kent, UK.
specs:
cpu: i3 2130
ram: 8gb
mobo: GA-H61MA-D3V
psu: 650w
os: windows 7 (64bit)
monitor: 2560 x 1440 (144hz) gsync
the monitor is overkill atm, as i am planning to get my newer pc built, and that monitor is meant to be for that.
tbh, i should prolong the life of this monitor and just plug in my older 1080 60hz jobby, as pushing my 660 to display some newer titles at 2560 x 1440 (even at 60hz) is too much!
i was looking at a gigabyte gt 1030 for £80, then i found out that it is actually slighly worse than the 660!
budget is for under £100.
i want to stick with nvidia.
can any of you out there give some feedback on whether this is a good step up?
a good step up pricewise and compatability-wise, basically.
cpu: i3 2130
ram: 8gb
mobo: GA-H61MA-D3V
psu: 650w
