Upgrading from gtx285 oc
10 Jun 2003
Looking to upgrade from a BFG GTX285 OC which is idling at 60 degrees so I may have to look at the airflow. I have a HX-650 PSU.
Would there be any issues running a 580GTX with my PSU ? :confused:
Nope... the GTX 580 is basically the GTX 485, runs cooler and uses less power than the GTX 480, and has an performance improvement as-well, so its a win win situation. You will have no problems.
