Upgrading from Intel i9 7900X to Ryzen 3950X?
1 Nov 2007
England
I currently have an Intel i9 7900X overclocked to 4.4Ghz, and I'm seriously considering an upgrade to Ryzen 3950X. The only problem I have is that the Intel CPU is prosumer CPU with unique features such as quad channel RAM, AVX512 and other things.
Would I be better off waiting for Threadripper 3000? Or would Ryzen 3950X be OK?
I usually run virtual machines on my computer, along with doing video editing using Adobe Creative Cloud.
Any help is appreciated.
Are you missing something with your 7900X system? Are you using more than 40-PCI-E lanes? Do you think you'll need more lanes, or faster PCI-E?
Why do you want to change? That would be the top level question. :)
Having more cores is always useful when you are running multiple virtual machines. The i9 7900X is a great CPU but it would be nice to have more cores and a bit more RAM. Plus added performance wouldn't hurt.
The thing is I run Windows 10 as my main operating system and then use VMWare Workstation 15 to run 2 or 3 instances of Linux which I use for programming. Having everything running nice and fast at the same time saves a lot of time in the long run.
It's hard to answer your question, unless you answer the query with regards to how many PCI-E lanes you are using. There's little point in being on HEDT anymore, unless it is for the PCI-E lanes, and the higher memory bandwidth, or you want more than 16 cores.
"More cores is always useful" Is that to a point, or is more always better? I ask since if more is always better, then the sensible option would be wait and then 24/32/40/48 core Threadripper 3xxx options are. Of course that is likely to be 4 months away at least, so is it costing you time/money or is this just something you'd like :)
As for PCI-E lanes I don't really need that many. I'll have two graphics cards and an NVMe SSD. The rest will be SATA. In terms of cores though I could use as many as is available. I do video editing on the side and will likely increase the number of virtual machines that I run in line with performance of the new computer.
