Upgrading from Radeon 5550HD, Need some recommendations
23 Nov 2010
Hey, looking to upgrade from ATI Radeon 5550HD series. My price range is around £50-100 and probably will make purchase on Overclockers.
I've found a few that look far better than mine but cheaper than I expected. Can someone recommend a graphics card in the price range that can run modern games, preferably BF3 and Skyrim on medium-high settings.
Thanks.
For 1920x1080 I have a gtx460 1gb and seems to handle everything fine as long as you dont mind turning aa off in some games. I would definately try and stretch to the 1gb version over the 768mb version. Both will be a significant improvement over your current card.
The 1gb version isn't really needed for that resolution but if your getting a new monitor then i agree.
